Hi Jon
The bottom end of the column is triangular shaped which should pass through Bulk head and the bottom bush [ford part] which is fixed to the engine side of the bulk head via a dax supplied bracket, the splined bottom then allows you to connect up the ujs and shaft to your steering rack, hope that makes it clear, Andy
