Thread: body fitting
Old 15-09-07, 01:41 PM
hfbradley01's Avatar
hfbradley01 hfbradley01 is offline
Body fitting
Originally Posted by viperjim View Post
thanks iain , i`m in warrington so a bit far to come and have a look . ive got one of the fitters at work making some brackets for bracing . You said you rivet`d the brackets to the body , did you just drill through the shell then grind and fill the rivet , i never even thought of doing that
Hi Jim
Iain and I fitted our bodies at the same time and in terms of bracketing are the same. I'm just the other side of Chester from you, so you're only about 1 hours drive from me. If you want to come and check out how we did it you're welcome.
Howard
Viper under construction - full steam ahead and hopefully on the road this year.
