Originally Posted by grizzly_a58 hi guys , posted same question in pilgrim forum, but thought i woulkd try closer to home as well. do i need to connect up the return pipe to my tank. or can i get away with just the feed. its a rover 3.5, twin su's running facet 5 to 6 psi pump what do you think. would suit me better with one pipe. but will it cause problems. if ok what do i do with the return pipe from the second carb. do i just blank it off, will it harm my carbs, i am lost. but hey? aint i allways. cheers grizz. |
Hi Grizz,
My Sumo has a 390 Holley 4 barrel on it and uses a Facet pump and is only using one pipe and is perfectly happy no flooding of carb etc, the holley does,nt use a return, but my mates Dax has SU carbs and he has the return blanked off and he is using a Facet pump ,and he,s had no probs.I think the old SU needle valves will hold back 6 PSI ok.It certainly wont damage the carbs the worst that can happen is they may flood on tickover,give it a try and if they flood connect up the return.
HTH
