re fuel pipes, hi brian , thanks for the reply. the reason i was asking about the pipes was, maybe i am just to fussy, but, the rout for the pipes everyone seems to take is down the outside of the chassis leg passenger side. ok good but? i dont want to see the fuel pipe showing in front of the rear wheel where it starts the run to the front. i was hoping to fill in the rest of the rear wheel arch at the front off the rear wheel, so you cant see right up the sill ,if you know what i mean, also, i thought what if somthing goes wrong with the fuel pipe and you need to replace it, what chance have you got ,trying to get to the pipe when the body is on. ok , i know i am being a bit paranoid, but ? so i thought i would run it down the inside chassis leg to the front , but inside the car. the reason i was asking about the feed and return was, the bloody seat belt fixing point on the inside is just a bit to close to the pipes, one would be ok, two will be a bit tight, am i being paranoid, cheers grizz. |
