  #30 (permalink)
Old 23-11-07, 03:14 PM
andicole0's Avatar
andicole0 andicole0 is online now
It takes how long!
The first cut! Well hole actually, I've managed to use a Dremel+attachment to make a pilot hole in the stainless steel engine bay and enlarge some with a normal drill to 6mm for the brake pipe holders. However in some instances I can't get a standard 6mm drill anywhere near the pilot hole or a 6mm bit in the Dremel.
So, any ideas how I enlarge a pilot hole in a difficult to access area? As you can see from the pictures the remaining holes I need to expand are blocked by the engine
I'll have a lot of trouble on the chassis for the rear pipes.
Cheers.
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/
Polishes to date = 2.
