Originally Posted by craggle It looked like my sump needed to be twisted one way to get it past the oil strainer but the chassis rails were in the way! I'm definitely not going to remove the engine and gearbox just to change a sump gasket.
You may need to modify the baffle / windage tray to get it to fit easily like I will tomorrow night.
Craig. |
Should be ok as this pan was moded by Mike Huddard and trial fitted to an engine he is building with the same issues as mine. I have a special oil pickup as the pan is very shallow. A shade under 7 1/4" on a Big Block Chevy........This maybe the only part to fit first time
