Originally Posted by slogger RCCob, have a look on my gallery. There are two pics from the early days of my Dax with a RV8. It had a plain cap just past the stat housing for filling with a bleed to the expansion tank. The setup changed as the bottom hose caused problems and that horrible bit of pipe from the stat housing was temporary.
Could always fit a large bore connection from the bottom of the expansion tank to the bottom hose as Dax now do. |
......forgot to add! ....and mod your stat housing to give an air bleed back to your expansion tank also, so you do not need to have that filler point on the top hose.
