  #17 (permalink)
Old 01-04-08, 10:14 PM
slogger's Avatar
slogger slogger is offline
Originally Posted by tonym View Post
The sumo header tank also has a breather pipe built in which goes to the top of the rad, come on Mike, you should know that I have no cooling/filling problems with my EFI Rover engine so perhaps the mod is only required with that particular inlet manifold/carb set-up
My RV8 setup had the connection to the top of the rad but this was much lower than the top of the intake. I had a bleed connection from the highest point on the intake, SU setup, and the top hose linked in with the pipe from the top of the rad with the head tank mounted on the rear of the intake manifold. No more problems, until now. Different ball game!
Ian DAX 454 Chevy
