Originally Posted by Miket |
Hi guys and thanks for the replies it has given me plenty to think about. So what I've done for a start is put a small bleed in the stat housing as hi as possible at the same time I replaced the stat for a 74 degree apposed to the 82 that was fitted. The other problem is the expansion tank dose not have an air bleed return to the top of the tank. It just has one at the bottom which at the moment goes to the top of the rad. If the bleed mod dose not work I will have to fit a pipe from the bleed to the top of the expansion tank. I have attached a pic of the expansion tank and the stat before the mods. I just need some fine weather to test it now
wish full thinking I know.
