| Forgot to mention the caliper adjuster.
They are adjustable as you know by turning the screw under that is held in place by a split pin
It sounds like you have done the right thing by adjusting until tight then backing off a bit. You may find the pads will wear slightly to match the disc once running.
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money!
Polishes to date = 17 |
