Originally Posted by cliffords Not on the road yet but when I shoot up and down the road I live in, I have noticed the steering is not too keen to self center. I does from a small lock but not from anything very hard. When I reverse off my drive it is keen when I turn to keep turning through to the lock , but this is when going back wards.
Do you think I have fitted something the wrong way around.
This is a pic of my car off side front. Are your shims in this way around ? |
Yep, the shims are the right way around so the top wishbone looks ok.
Have you checked the bottom wishbones, are they on the correct side, ie the "swans neck" bottom ball joint mounting points forward slightly. If you have put these on the wrong side the top wishbone camber won't make any differnece whatsoever, but your self centering in reverse would be great!!
Tony
