20-04-08, 06:24 PM
| Senior Member | | Join Date: Nov 2005 Location: Horsham,West Sussex
Originally Posted by TonyD Yep, the shims are the right way around so the top wishbone looks ok.
Have you checked the bottom wishbones, are they on the correct side, ie the "swans neck" bottom ball joint mounting points forward slightly. If you have put these on the wrong side the top wishbone camber won't make any difference whatsoever, but your self centering in reverse would be great!!
Tony | Yep swan neck is forward .
Thanks for the replies.
__________________ David Clifford
AK427, Tremec and Stroker. |
