Just to confuse things further
There are 3 types of top wishbone! Curved with equal offset. Straight Cranked with equal offset and Straight Cranked with unequal offset. Looking at Davids picture he has the later. So moving the shims forward should sort the problem
Craig I think the rounded top bolt is only needed if you still have the shield (which most of us don't) I changed it for a normal hex head because with 4 shims there is not enough thread showing past the nyloc for SVA purposes. And it doesn't rub
