Thread: Self centering
  #15 (permalink)
Old 20-04-08, 10:07 PM
TonyD TonyD is offline
Nearside..............no wonder I was a bit confused, I didn't look at the rest of the picture I was looking at the hub and the wishbone. IIRC from when I put mine together your upper wishbones as they are at the moment are reversed. . The larger "knuckle" into which the bump stop used to bolt should be towards the front, you've got it on the back, and the shims should be on the front face of the upper ball joint, not rear as you have them now. That will sort the problem. Cheers, Tony
