Thread: Self centering
  #17 (permalink)
Old 21-04-08, 08:11 AM
dave's Avatar
dave dave is offline
Tuuurn up da bass.
It looks like the bolts holding the ball joint to the wishbone are in the wrong way around, Well, the outer one is anyway.(That is if you are leaving your shims there).
The head of the bolt should always go closest to the shim pack as the disc can get very close to the nut and thread on full lock when the ball joint is off set in the other direction.
That's why the original Jaguar bolt had a domed head.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
