Originally Posted by mikey Hey up Dave - how ya doing. Did you sort out the carb issue?
Temperature in Yorkshire has gone up 15 degrees in about 2 hours and the bees have started buzzing about - summers on its way - or is it summats on its way?
Also spent the last 2 weeks putting the revised de dion front end on the cobra which gives much more castor - not much fun I have to say - preferred the haircut.
Are you going to Stoneleigh?
Mike |
Hello M8.
Sounds like you have lost the plot too!!
I'm good, my carb was full of swaf! Cleaned it out,took it to tim's and he retested it on one of his motors, it was alittle lean off throttle so he fitted a smaller idle air bleed. I will retest it on my car,but won't hold my breath!
I bought a 2nd carb, 750 speed demon with vac sec and it gave a much nicer fuel curve so I think I will use that one instead.
Yes I will be at stoneleigh,need to get my finger out and refit my exhausts, see your there if your going!
