Hi Jan & Chris,
Not sure if this will help, but I had a simiular problem on my Mk III. Eventually found that one of the rear drums (off side) had a crack in it. I can only assume that with it being cracked the hydraulic system somehow "pulsed" and with split brake curcuit this had an effect on the front nearside wheel. If you`ve got disc`s on the rear then I don`t think it could be the same situation.
Bob |
