Old 02-05-08, 09:59 PM
Iain's Avatar
Iain Iain is offline
Herd member
Originally Posted by Sideways View Post
Hi Tinka,
Can I ask more advice please...I should collect a 302 V8 next week and have sourced a Getrag gearbox. Now need a clutch, flywheel, clutch fork and bell housing.
I have seen you comment that there are two bellhouse sizes...any ideas what I should source to ensure a fit to a Getrag through thr AK adapter unit ??
Thanks,
Sideways.
Hi,
I've got a Ford 302 and have just fitted a Getrag gearbox.
I believe you can get the clutch and pressure plate from Real Steel and maybe the fork and release bearing too.
The bellhousing is related to your flywheel. There is a 157 tooth and a 164 tooth flywheel. Get the wrong pair (as I did) and your starter won't engage the flywheel (or possibly worse!). My original setup had a 157 tooth flywheel on a bellhousing suited for a 164 tooth flywheel.
Just be cautious (check exactly what you are buying) as you purchase your parts and you'll be fine.
Cheers...
Iain
http://www.fake-snake.co.uk/
Classic Replicas Viper
SVA'd Nov 2007
