Originally Posted by jeff I can not manage Stoneleigh on Sunday any one going on Monday |
Jeff,
I'll be going up on Monday too - but unless the weather forecast improves I suspect it will be in the tin-top. Hopefully the sun will make an overdue appearance, as I've now fixed my slipping clutch, followed by a seized clutch mechanism, and I also seem to have cured the RH exhaust manifold air leak that was causing some almighty bangs on the overrun.
All I need to do now is to replace the leaking core plug ........
