| here's a pic of the head and the manifold. Does the centre port on the manifold simply connect the two drillings to the exhaust ports (and if so why??) or is it a coolant port and I've ordered something wrong?
Also the compression ratio is working out at 10.2-10.3, is this useable or should I be checking the dynamic ratio to make sure all is ok?
__________________ Lloyd B
De dion Dax - 383 SBC with AFR 195's, how much more can this thing cost?! - Ah that much more! |
