Old 07-05-08, 09:11 PM
RichardG's Avatar
RichardG RichardG is offline
I think the standard advise is to grease the mounts up with lard (or something else that will lube up the mounts but not rot the rubber). Also I think elongating the holes might not be a good idea, its bound to get the body in the wrong position that way. Have you got the body on four trolley jacks (one on each corner) so you can move the body around to line up on the mounts. Good luck.
Richard
GDtastic
