Old 07-05-08, 09:16 PM
Simon R's Avatar
Simon R Simon R is offline
Originally Posted by RichardG View Post
I think the standard advise is to grease the mounts up with lard (or something else that will lube up the mounts but not rot the rubber). Also I think elongating the holes might not be a good idea, its bound to get the body in the wrong position that way. Have you got the body on four trolley jacks (one on each corner) so you can move the body around to line up on the mounts. Good luck.
Greased them up with vaseline - went on no probs. I think I could move the body up to align the holes..... but then it won;t be sitting on the foam on the tunnel sheet.... is that a problem... if not then it begs the question as to it's purpose?
Simon
GDJAG
Chassis Now Rolling!
BAE 383 SBC in and running
MKIV Body fitted
What's Next
http://str-427-cobra.blogspot.com/
