| I didn't use the easi bleed kit because I had the same problem. Used another form of bleeding kit though that was meant to do the job just as well (bit of tube with one way valve as far as I can tell). See previous posts, but in short the only way I managed to do it in the end was the old fashioned way - 3 people makes it very easy - one to pump, one at the bleed nipple and one at the reservoir.
The Jag system does seem to require a lot of bleeding though - took forever on mine. |
