Old 08-05-08, 08:35 AM
ian_uk1975 ian_uk1975 is offline
Originally Posted by craggle View Post
This probably won't help but my water temp sender is in the head. There is a big plug in between number 1 and 3 cylinders and my temp sender is there.
It could be in the inlet manifold but this will only be the water temp gauge. Oil pressure and oil warning light are normally on a Tee piece on the back of the block behind the distributor.
Oil temp sender will be in the oil filter area, In the oil cooling lines or in the side of the sump.
Excellent info... just what I was after. Thanks Craig.
Location of water temp sender between 1 and 3 plugs probably explains why my temp gauge isn't working... the sender is very, very close to the header pipes! Will have to remediate and wrap with heat-reflecting tape.
Ian.
2003 DAX Tojeiro De Dion
