Originally Posted by RichardG IIRC I fixed one bolt loosely (most likely the rear most one on the trans tunnel) and then got the one on the opposite side in next and worked my way forward along the body, jiggling the body up & down to align it as I went.
I guess the foam will have a fair amount of play in it so "resting on it" could actually mean lots of things from just about touching it to crushing it completely, so I guess its worth having. |
I found that by jacking and packing under the body floor I could get the mojority of holes cock on - particularly the ones on the front bulkhead.
However - disaster struck when the threaded insert on the offside front bulkhead mount became detached from the mount!!
Fortunately I found that by jacking thebody up 9 inches at the front and 12 at the back I could roll the chassis forward just far enough to undo the mount with a spanner and withdraw it. Close inspection showed it to be slightly deformed and the crimp wasn't formed correctly (rivnut type affair)
So currently sat waiting for a replacement mount from GD. 624 days to date so a couple more is neither here nor there I suppose.
Not a good day, but at least i didn't have to re-assemble the troops the lift the body off.
