Originally Posted by Neil O A small fire extinguisher hitting you on the arm as it then travels through the dash and windscreen, probably stopping halfway through whatever you just crashed into, will be the least of your worries.
I fitted mine in the Dax, between the seats on the rear bulkhead (careful you don't drill through the battery...ala Rodders).
Not sure where to fit it on the Crendon though. Probably in front of the seat like Lee says. |
Pray you don't get someone hititng
you up the rear with a lethal projectile equipped car like yours. Your head will explode into 1000 pieces if it hits it.
You could mount it between the passenger seat and door on top of the sill. The retaining cage will prevent it coming loose in an accident as it will be lying horizontal and in line with the direction of travel.
