Top harness mounting bolts
Hi Guys,
I just been trail fitting the willans harness supplied by dax, in the manual it states the bolt length should be at least 1 3/4" in length. However the bolt supplied is only 1 1/4" long. This means that by the time the bolt has passed through the rear stay and the body there's only a coouple of threads engaged in the chassis.
Not a problem i thought, just order some longer bolts. but none of the bolts have "8.8" Or "S" on them, which i believe is an SVA failure. The bolts do have Three lines on which i believe is the ISO equivilant, is this OK.
If not does anyone know where i can get some correctly marked bolts.
Many Thanks,
Russ
DAX DE DION - HUDDART 383 - 452bhp & 466lbft Torque
