Hi Russ,
Can't remember whether the bolts were Dax supplied or supplied by Willans I'm afraid but what I do recall (because they were such a pain in the ar** to get in) is that the bolts supplied fitted fine once the rear stays of the roll hoops had been persuaded to line up with the chassis.
I suspect that you have the wrong bolts supplied by Willans or Dax. Worth being spot on on this point as the SVA inspector was very particular about these bolts on ours (evidence that it all came from Willans etc). I suspect only because they are very obvious on the test.
Jon
