  #12 (permalink)
Old 09-05-08, 08:34 PM
alfiebeard's Avatar
alfiebeard alfiebeard is offline
Location: Annan Dumfriesshire and work in Carlisle Cumbria
Punching Chassis Numbers
Originally Posted by cliffords View Post
I have already 'failed' my DVLA inspection having a riveted plate. It has to be a welded plate or stamped on the chassis from the perspective of Brighton DVLA.
My Last Sumo failed the local DVLA inspection in Carlisle,(beware Toddy) they said the numbers must be punched into a chassis rail,(I had 1 stamped plate from Pilgrim)on the bulkhead (rivetted) and also a printed foil one on the chassis, and they made me get it stamped before they would pass it, this test was only conducted because I was removing the number prior to parting with the car, I got my mate to stamp it into the RH front suspension bracket, and when the inspector wanted to inspect it she nearly refused to kneel down to read it!!.I suppose it depends on the examiner, but next time I will be stamping the number on the chassis rail in the boot.
Alfie B
Blue Sumo Mk111 RPI 4ltr crossbolt V8 Piper cam Webber 4 barrel freeflow headers Mallory dizzy Jag running gear with powerlock Diff.
