Originally Posted by TINKA My engine is plus 30 and I use standard gaskets, to be honest I did not know you could get different ones  I guess if they sell them fit them  if you can't find them that is cos they don't exist  |
Ok, that means my Victor Reinz gaskets from Real Steel will be OK in mine then! Cheers.
Yep, you can get SBC head gaskets in a variety of bore sizes. After some more Googling and forum-hopping, the general concensus seems to be that you should run a head gasket that is, if anything, slightly larger than your actual cylinder bore size. I'd go and measure the Inside Diameter of my Victor Reinz head gaskets with a vernier caliper, but they're sitting in the passenger footwell of the car (which is in my rented garage) right now.
Ian.
