| Sierra collapsible column Guys,
I want to check that the sierra steering column i am using is sva compliant. ie collapsible.
Could someone point me to the bits on the column that are collapsible,
Im not sure, but the bottom column has 'bellows'. Is that the collapsible part, if it is then i will need to use that one.
or is it the extension part that is 'collapsible'.
I spent alot of time shaping the cowling to fit the dash which will have been in vain if i need to use the other column.
Jim
__________________ How are the doors and bonnet supposed to fit again ?  . |
