| Hi, just looking through this thread reminded me of a common problem a while ago when the centre support bearing in the flywheel (sometimes needle roller or bush) could stick or get clutch dust in it. This resulted in the bearing, instead of allowing free rotation, turning the spiggot shaft when the clutch was depressed (worse when hot) enough to make stationary gear selection difficult.
Only solution was box out Im afraid, worth replacing while doing your clutch though!!
Richard |
