Old 14-05-08, 02:53 PM
mike huddart mike huddart is offline
Originally Posted by ian_uk1975 View Post
I want to upgrade my stamped steel rockers to roller rockers. Question is, do I need self-aligning rockers, or not? My understanding is that SA rockers are generally required if the head does not have guideplates (which my heads don't have). However, I've read conflicting statements regarding whether SA rockers are needed, or not. So, I've attached a pic of one of my heads below, with the pushrod and rocker removed from #8. Comments?
Ian.
Ian,
those are self aligning rockers but someone has converted the heads to screw in studs so in theory you could use guide plates with that setup and regular rockers. However the pushrod holes look a bit on the small side so you might end up with an alignment problem unless you enlarged them, thats a head off job though.
Oh, and seeing your looking for comments thats #2 not #8
Regards Mike
