Originally Posted by mike huddart Ian,
those are self aligning rockers but someone has converted the heads to screw in studs so in theory you could use guide plates with that setup and regular rockers. However the pushrod holes look a bit on the small side so you might end up with an alignment problem unless you enlarged them, thats a head off job though.
Oh, and seeing your looking for comments thats #2 not #8
Regards Mike |
Oops, I meant #2! That's embarrassing.
So, I need self-aligning rockers with my current set-up, or ditch the current heads, buy some Patriots from you and get some normal roller rockers
Before I do that though, I need to whip these heads off, ascertain what pistons I have, measure my deck height and quench, cc my chambers and figure-out what chamber size I'm going to need if I upgrade the heads. Heck, I also need to measure cam lobe lift with a dial gauge to establish (beyond reasonable doubt) what cam I've got (although I'm pretty sure it's a Performer RPM).
Ian.
