Originally Posted by mike huddart Ian,
no, you could use normal rockers if you fit guide plates and some of the work(screw in studs) has allready been done.
Mike |
Not sure I want to goto the hassle of fitting guideplates and, potentially, running into binding problems requiring machine work to the heads. Once I've ascertained where I'm at wrt. pistons, deck height, quench and cam, I suspect a new set of heads maybe the order of the day.
Ian.
