| Cheers Dave,
Ok I'll reprint the page and won't tick 'C', I was just following the DAX SVA guide.
I've measured the noise from my 2" baffled DAX side pipes and the worst case is the nearside pipe which hits 101Db at approx 3700 rpm. So I have decided to put 4000rpm as my max engine power on the application form.
I have put 130mph for top speed, seemed reasonable.
I can't see anything else concerning on the form, do you have any other advice?
Hope Stonleigh was good for you
John
__________________ If you drive a Cobra you are going to get wet.
Dax Toj 350ci Chevy, Tremec TKO600, 5" Sidepipes |
