Originally Posted by Purple AK Ian. Talk to Jez @ Custom Power & Paint 01797366900 He built the engine for BAE and should remember the original spec and any alterations hence  |
Yea, I could give Jez another call, but, in all fairness, he doesn't have the build sheet (taken with loads of other paperwork when his original premises was burgled several years ago). He may remember PRETTY-MUCH what the spec is, but he can't be certain down to the kind of detail level I need to make an informed decision about new heads, etc, hence the detective work I need to do to remove any uncertainty from the equation. For instance, Jez can't be sure if I've got domed or flat pistons; he thinks I've probably got domed. However, Ian @ BAE reckons I've got flat. How can I be sure? Whip the heads off and look for myself
Ian.
