| Warren,
It sounds like a plug or two were fouled out do the the rawl fuel being dumped into the engine.
I would change all the plugs and start from there.
The carb was adjusted fine before the trash in the needle and seat. I would not be messing with it until I looked at other things that don't involve messing with the carb adjustments other than reseting the float level of the rear bowl.
__________________ Tony "I couldn't repair your brakes, so I made your horn louder."
A Black Unique Motorcars 427S/C 427FE 482 stroker close ratio toploader 3.31 Jag IRS |
