Old 15-05-08, 01:46 PM
chedz's Avatar
chedz chedz is offline
Without taking the bracket off (and messing up the speedo) a photo might be tricky. Attached is a diagram of what I did.
Get a bit of stainless sheet and cut out a shape like that shown, then bend back by 90 degrees the little flaps on the side with holes in, then attach it as Pete has said via the same bolt holes as the diff carrier bracket.
hth
G.
