Old 15-05-08, 10:40 PM
slogger's Avatar
slogger slogger is offline
Originally Posted by RCCob View Post
This is only pic I have at the moment, also the bolt you can see in the center of the mounting bracket seems to be just a bolt with a piece of rubber round it and not a proper mounting bush, is this correct?
Yep, it looks like an SD1 LT77. That is an SD1 gear box mount you have and the centre bolt goes through a rubber bobbin that locates into a hole in the cross member. I believe this is to limit the movement of the tail end of the gearbox.
As for your gear selector remote, I can't really comment as it is not visible.
Ian DAX 454 Chevy
