Originally Posted by slogger If you have the shortened SD1 remote, it is only a case of setting the spring pressure with a couple of bolts and lock nuts. All in the Haynes manual for the Rover. I set mine so you had to snap it across to get reverse.  |
Thanks will give that ago before trying any mods to gear stick
