Originally Posted by stu e Hi Steve
I had my clutch conversion supplied by Magnum, and couldn't get the clutch to disengage. They questioned my bleeding the system ( I put litres through it with the bleed nipple to the top) and suggested araladiting a nut to the end of the slave pushrod. I never tried sticking a nut on the pushrod but ended up fitting a bigger bore master cylinder.
My problem was the clutch never worked, I've heard of people taking the slave cylinder off to bleed the systrm but haven't tried that myself.
Stu. |
Hi Stu. I have tried bleeding it with the slave cyl removed. Was yours ok when you fitted the bigger master cyl. Steve.
