Originally Posted by stevem Hi Stu. I have tried bleeding it with the slave cyl removed. Was yours ok when you fitted the bigger master cyl. Steve. |
Yes mine has worked fine for 3 years now, but as i said my clutch never worked, were as yours semms to be intermittent.
As Wilf says it could be a duff master cylinder, I think TonyM had that problem a while back, the non return valve in the master wasn't sealing, and pushing the fluid back into the resevoir, when you press the clutch does the fluid level rise?
Stu.
