| Simon the picture posted by Craig shows the same mounts and the welds that are causing the problem. I don't want to take anymore off the welds on the mounts to make them fit.
Craig, your comments are indeed helpful as you have clearly had the same problem and have confirmed my thoughts. Time to take a big file or the angle grinder to the Powder coating on the chassis!! Annoying but it'll have to be done....Sod it!!
Thanks guys
Denis
If you take something to bits often enough, eventually you'll have two of them...... GD427E039 |
