Old 17-05-08, 07:50 PM
hfbradley01's Avatar
hfbradley01 hfbradley01 is offline
Originally Posted by Marty V6 View Post
Hi,
I have ETB instruments in my Cobra, and use a wheel with holes in it (daisy wheel type) which is bolted to the prop flange and the sensor counts the holes rather than sensing the magnet. Car came like this when I bought it, so I can only presume that this kit was sourced from ETB. No chance of anything coming flying off with this set up, and have never had a problem with it in the four years I have had the car.
Marty
Hi Marty,thanks for the reply.
Tony has confirmed that the LT77 gearbox (standard R/3 gearbox) has a built in unit for an electronic speedo, it would make sense to utilise this,and eliminate the work and risk of adding an additional sensor.
I've seen the setup you mention and I'm sure it works just fine.
Howard
Viper under construction - full steam ahead and hopefully on the road this year.
