Old 18-05-08, 05:56 PM
dolphinboy400's Avatar
dolphinboy400 dolphinboy400 is offline
Originally Posted by bitsilly View Post
The petrol tank looks bigger than my one, but if it is the right size, there should be a tab above the tank in the middle, then two more point below where thos bolt heads are showing. An inverted V shaped bracket then attaches to hold the tank in.
Removing the body is a big job only worth doing if you are in the mood for a major rebuild.
To get the body off all the loom will need to be threaded out of where it passes through the body, disconnect handbrake or cut body around it, steering column out, pedal box needs to be removed, front and rear sub frames out (so radiator out) etc.
I would say the Ram is worth sorting as it is certainly one of the better chassis but removing the body is such a big step, you are talking do a full rebuild to make the most of having the body off.
I would advise you to ring me as I am in the middle of doing all the above, and there is much we could talk about!
Ward for example sell polyurathane bustse for the front, I have fitted power steering and traction control, the bonnet hinges could be re-done to allow the bonnet to go up further, there is an easy mod to allow twin roll bars if you have an early chassis etc................
If you fancy a chat pm me with a phone no.
Ed
you have a PM
Danny
L&R Ram 3.9 RV8 - in need of some love
