Old 18-05-08, 09:04 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Copper tubing for Brakes?
I saw on another thread what looks like copper tubing and compression fittings for brake lines.
I would never dream of using copper tubing in a brake system and definitely not compression fittings. It is not legal in the US to do.
The tubing does not look like the 90-10 copper-nickel(cunifer alloy)tubing.
It looks like regular plumbers tubing which is is run right against the steal components of the chassis. This can cause electrolysis and cause the tubing to fail.
Are you running silicone brake fluid in these system?
Tony
"I couldn't repair your brakes, so I made your horn louder."
A Black Unique Motorcars 427S/C 427FE 482 stroker close ratio toploader 3.31 Jag IRS
