Originally Posted by chesterak In my view, the ESSENTIAL things you have to do are; change the v5 engine number to actual number of the engine you are fitting, make sure you have the correct engine size stated, if the transmission has changed, for example the original is auto and you are using a manual box, change this also. |
Hi Stan.
That is BIG No No.
If they suspect you have done a "Paperwork engine swap" your application will be thrown out. This used to be a popular trick for the bike engines super 7 guys who wanted to get a late model bike engine through SVA without it having to pass a car cat emissions test.....900cc Sierras for example!!!
If the engine does not have the same capacity or look like a Jag (in this instance) engine when you turn up for the test (If you even get that far) there is a very good chance you will be sent home with a "Refusal to test" letter.
Bending the rules is a thing of the past nowadays, the techincal department at VOSA are much more clued up these days.
