Old 19-05-08, 09:12 PM
tonym's Avatar
tonym tonym is offline
Club Chairman
Originally Posted by stevem View Post
Hi Tone. I think you got hold of wrong end of stick. I am looking to go from carb to EFI, Cheers Steve.
Whoops, Er yes it is simple i did it some years ago. decide whether you want to use the rover ecu or go megasquirt then pick up a full efi kit off ebay (hotwire system is better but flapper type will do. you'll need a high pressure fuel pump and a return line back to the tank too plus a proper efi fuel filter before the injectors. It's then simply a case of replacing everything from the inlet manifold upwards and wiring in the ecu (the rover one comes as a seperate loom). If you'd like any more info let me know and i'll pm you my number for you to call for a chat sometime
BIG TONE
