Originally Posted by FatBoy Presumably, that was for water and not the "go faster" juice that we're talking about, considering that petrol is lighter than water.
Paul |
Sorry I left that part out. Yes it is of water.
I have a close ratio toploader (large input/output) with a 2.88:1 Powrlok. The 'box came from SA along with the engine.
Paul,
Let us know what you think of the combination once you get it running properly.
And go through the engine and re-torque all the bolts you can reach to the proper specs including the crank bolt and the bell housing bolts.
And after each run check your header bolts. Especially with alloy heads.
